Текущее время: 19 июн 2025, 14:51
Начать новую тему Ответить на тему  [ Сообщений: 66 ]  На страницу Пред.  1, 2, 3, 4  След.
СообщениеДобавлено: 23 авг 2006, 18:27  Заголовок сообщения: (no subject)
ЗК писал(а):
Вообще АбАрзели тАварищи в кАЗине - в Sonnar T* 2/85 ZM ничем похожим на соннар даже и не пахнет - гелиус обычный.
2/85 выпускает цейсс а не косина, т.к. они не могут серийно выпускать объективы с плавающими элементами.
По поводу Зоннар это или Планар уже было сломано много копий. Для справки мнение от собственно цейсса:
Originally Posted by Dr Nasse
Dear Mr. Bignell,
With lenses it is sometimes as it is with humans: there are certain types or races, which have their characteristic appearance and distinguishing features. But after centuries of mixing, there are as well nearly all shades in between.
The same is nowadays true for lenses. In the early days of photographic optics some types have been created with a specific layout with respect to curvature and thickness of the lenses, position of cemented surfaces, distribution of the refractive powers and of particular glass materials in the system. And these lens types received names, which the maker reserved as a trademark.
Because of these protected trademarks and because of the gained reputation of some of them these names are still used today. Sometimes however there is no technical similarity between the old type and the modern namesake; this is especially true for zoom-lenses. A Vario-Sonnar has not much to do with the original Sonnar type.
In other cases it is like with a child, where you can see the genes of father and mother. There is a similarity to both of them. The Sonnar 2/85 ZM is an example for that case: The basic layout looks very much like the classical double Gauss lens, which is usually called a Planar in our company. But if one has a closer look to the distribution of the refractive powers, one will notice, that the strongly curved front element has much more power than normally in Planar types, with respect to that feature the lens is more nose-headed, as it is typical for a Sonnar type. If you take a Sonnar, e.g. the 2.8/85 for the Contax and split the cemented rear group into two separate lenses, and if you add a floating rear element for the stabilization of image quality at close focus distance - then you arrive quickly at the scheme of the new 2/85.
So it looks like the father, but has the character of the mother. But since double-names are not common in lens naming, we had to decide for one.
With best regards
Dr. Hubert Nasse
Carl Zeiss AG
Camera Lens Division, Laboratory
[personal info removed]
Internet www.zeiss.de/photo
Еще повторюсь, не надо думать что кругом идиоты да жулики. Если вам что-то кажется странным на то могут быть причины которых вы не знаете, а не чья-то злая воля.
СообщениеДобавлено: 23 авг 2006, 18:31  Заголовок сообщения: (no subject)
Ну да -причины которые знать не положено. Или по русски - бабушка лучше знает хочешь ты писать или нет.
Спасибо -я не такой идиот. Очевидно что они упрощают и удешевляют технологию как только иогут.
общество без цветовой дифференциации штанов не имеет цели
СообщениеДобавлено: 23 авг 2006, 18:33  Заголовок сообщения: (no subject)
Мда. Вы пробовали прочитать то что я запостил?
Если введение плавающего элемента для вас упрощение и удешевление, о чем тут можно говорить.
СообщениеДобавлено: 23 авг 2006, 18:40  Заголовок сообщения: (no subject)
да прочитал я , прочитал. Этот плавающий элемент там ни в п... ни в красную армию ненужен - предназначен для развода лохов и полностю ломает классическую проверенную схему. Как говорил один мой знакомый генерал -я бы таких рацонализаторов на фонарных столбах вешал.
СообщениеДобавлено: 23 авг 2006, 18:47  Заголовок сообщения: (no subject)
Я хочу классический зоннар без всяких улучшений со сдвигом фокуса как положено, а не со всякими плавающими элементами, которые созданием видимости удобства для фотографа ухудьшают хорошую схему и качество изображения.
И даже - с однослойным просветлением !
СообщениеДобавлено: 23 авг 2006, 19:38  Заголовок сообщения: (no subject)
Барахолки на иностранщине, советские Юпитеры и ЗК-8 всех мастей из тайных мест (тм) - Спасут отца русской демократии?))))
СообщениеДобавлено: 23 авг 2006, 20:08  Заголовок сообщения: (no subject)
Конечно спасут !
А ситуацию с цеёссокозиной я бы так прокомментировал. Точить настоящие стеклянные линзы дорого, склеивать их ещё дороже. Ибо нужно натуральную смолу и квалифицированные руки сборщиков. Потому казиновцы решили сэкономить в сложной схеме (говорят сборка настоящего зоннара - более 1000 ручных опеарций требовала) по 1-2 линзе (полировка 2-4 поверхностей). Линзы с возу- казине легче.
А уж какой процент брака при склейке ручной -вабще ужас для экономики буржуазной.
Второй фактор - полная автоматизация сборки объективов с минимальными затартами народных масс - никаких склеек, всё полируетс я и штамуется на роторно-конвеерной линии.
И тут выяснилось -кастрирвоанный зоннар с фокусом 85 - н етолько не дотягивает д остарого на бразильском лантановом стекле, но и просирает ему по полной программе. Тогда они вспомнили что у них есть подвижный элемеент (не плавающий -там иммерсии нету) - и пытаются им выправить ситуацию, нсеколько оптимизируя паршивенькую схему по расстоянию. Да и лохов легче убедить всякими там плавающими элементами. А что где там плавает ?
СНижают цену изделия и максимизируют получаемую прибыль.
Вот и вся сермяжна правда.
Завтра они придумают ещё что нибудь этакое и кончится всё пластиковым зумом.
СообщениеДобавлено: 23 авг 2006, 20:14  Заголовок сообщения: (no subject)
Все это круто, но ширик все равно придется покупать косиновский, что на дальномерку, что на шкальник)))) А полтинники и портретник - безусловно советские рулят...
СообщениеДобавлено: 23 авг 2006, 20:52  Заголовок сообщения: (no subject)
Kstati govorya, Sonnar 90/2.8 dlya Contax G poluchaetsa toje ne Sonnar, esli sxemu posmotret'...
Posmotrev sxemy sovremennyh ob'ektivov Zeiss'a i Leica ya uvidel lish odin Sonnar: Leica'ovskiy 50/2.
Po chisto tehnicheskim harakteristikam (MTF, distorsiya, vin'entirovanie) Zeiss ot Cosina vpolne normal'niy, daje ne huje Leica (ya smotrel glavnym obrazom shiriki).
"Четкость - буржуазная концепция", Анри Картье-Брессон
Contax G2 + 45/2 + 21/2.8 + 90/2.8
Bessa R3M + 40/1.4 + 50/2 + Ю-9 85/2
СообщениеДобавлено: 23 авг 2006, 21:06  Заголовок сообщения: (no subject)
Вот насчет виньетирвоания я бы сказал что коЗинвоский соннар 50/1.5 очевидно хуже старого. Дел ов размере последней линзы. В старом она была больше по диаметру чем первые два компонента склейки - и сделано это было именно для предотвращения виньетирования. А в современном псевдосоннаре на диаметре и толщине последнего компонента явно сэкономили.
Про ширики - Юпитер-12 от КМЗ - самй лучший ширик. КаЗине со своими псевдоБиогнами-2 (по руссарвоскому принципу построенными) до него ох как далеко.
СообщениеДобавлено: 23 авг 2006, 23:20  Заголовок сообщения: (no subject)
Ясно :) Если Цейсс делает что то более новое чем использует схему посчитанную вручную 75 лет назад и соотв. материалы - это ревизионизм и "впаривание лохам"; если нет - это то что "в СССР в 50х делали" и снова "впаривание лохам". Позиция конечно безупречная :)
СообщениеДобавлено: 24 авг 2006, 00:01  Заголовок сообщения: (no subject)
Надо всегото меньше врать и меньше экономить на стеклах. И народ к ним потянется. История появления Юпитера-17 - похожей на каЗиновский псевдоссоннар схемы точно такая же была. Хотели сделать упрощенный народный объектив -подешевле. Но этого никто и не скрывал, в отличии от цейсса идущего по пути улучшения технологичности изделий, а не совершенствования проверенных оптичсеких схем как таковых. Это же очевидно. Особенно в свете грядущего переноса производства каЗины в китай.
Если уж они такие крутые - пусть каЗина сделает Топогон ( нулевой дисторсией теоретически - у топогона дисторсия определяется только технологичесикми допускам ина сборку) или Биогон-1 - слабо же, так ка эти схемки посложнее соннара будут.
Опять от имени народа подорожала колбаса (соннары тоесть) ! И туалетной бумаги в нее класть больше стали.
СообщениеДобавлено: 24 авг 2006, 00:44  Заголовок сообщения: (no subject)
Старый биогон слишком сильно виньетирует для 35мм по современным меркам, что особо хреново будет выражаться на цифровых сенсорах. Кроме того его не всунешь в большинство выпускаемых сейчас камер. Но технически сейчас его воспроизвести колоссальной сложности нет. Особенно если перед этим что-то вроде Хологона без проблем осилили.
Ну да ладно, мировой заговор так мировой заговор. Живите в пятидесятых :)
СообщениеДобавлено: 24 авг 2006, 09:42  Заголовок сообщения: (no subject)
А новый на 1.5 кропнутой матрице не будет конечно виньетировать.
Вот она сермяжная правда !
А камеры нормальные - как у людей - кто казине выпускать мешает ?
СообщениеДобавлено: 24 авг 2006, 09:49  Заголовок сообщения: (no subject)
Это не заговор, а отупление и оглупление людей. Весь мировой прогресс давно идет по пути упрощения и отупения.
Понятное дело -если казина решила таки делать объективы для цифры, тоей глубоко насрать на рисунок. На цифре рисунок объектива разглядеть сложновато - вот и можно вынуть пару ненужных линз как им кажется.
СообщениеДобавлено: 24 авг 2006, 11:39  Заголовок сообщения: (no subject)
ЗК писал(а):
А и Б сидело на трубе ! Кто остался на трубе ?
Объясните пожалуста за счет чего в схеме у которой удалены 2 лишних коррекционных параметра разрешение стало лучше ?
почитайте leica lens compedium (если я не ошибаюсь - это оттуда)
Erwin Puts там пишет примерно следующее: "тонкие воздушные прослойки тоже могут использоваться как элемент общей схемы со своими характеристиками"
примечание 1: Вы никогда не задумывались почему лейтц и цейсс во все времена и всеми доступными средствами стремятся к минимизации количества оптических элементов?
примечание 2: вот тут http://rangefinder.ru/club/viewtopic.php?t=102
"A designer would cement two glass elements together ( or split one element into two separate lenses) to create a glass type that is not available in the glass catalogues. Basically the Elmar is a triplet, where the last lens element is cemented to generate a new type of glass, that was needed for the computation."
т.е. в 30-е просто не было тех марок стекла, что доступны сейчас, что иногда требовало применения склейки 2х линз там, где теоретически можно обойтись одной
СообщениеДобавлено: 24 авг 2006, 11:56  Заголовок сообщения: (no subject)
sonnar тот
sonnar этот
и что? по Вашему, если уж склеили один раз, то надо склеивать всегда? бред
примечание: а давайте посмотрим на зоннары которые делал сам цейсс для Contax RTS или Contarex
СообщениеДобавлено: 24 авг 2006, 11:58  Заголовок сообщения: (no subject)
Костя, не старайся. Щас тебе снова выдадут что цейсс просто на канадском бальзаме экономит.
СообщениеДобавлено: 24 авг 2006, 12:03  Заголовок сообщения: (no subject)
...Я хочу классический зоннар без всяких улучшений со сдвигом фокуса как положено, а не со всякими плавающими элементами, которые созданием видимости удобства для фотографа ухудьшают хорошую схему и качество изображения.
если снимать только достаточно удаленные объекты, то плавающие элементы и в самом деле - не в п
а вот если снимать портреты (а соннар 85 прежде всего как портретник позиционируется), то плавающие элементы очень кстати, что подтвердил и Erwin Puts, сравнивавший недавно Sonnar ZM 85 с современными Summicron-ами 75 и 90 (у 90-го нет таких "излишеств" и он проигрывает соперникам на ближних дистанциях)
СообщениеДобавлено: 24 авг 2006, 16:13  Заголовок сообщения: (no subject)
Вообще-то тон дискуссии задан уже в названии темы. Не понимаю, как Вы столь долго беседуете с ЗК. :oops:
"Ничего не сделал, только вошел" тов. Саахов
