| Пусть будет в этом разделе :) (Проявка в кофе №567888) https://rangefinder.ru:443/club/viewtopic.php?f=10&t=4978 |
Страница 1 из 1 |
| Автор: | serzz [ 18 янв 2009, 10:57 ] |
| Заголовок сообщения: | Пусть будет в этом разделе :) (Проявка в кофе №567888) |
http://bigrasta.livejournal.com/36653.html |
| Автор: | cfif23 [ 18 янв 2009, 11:02 ] |
Здесь, наверно, человек начитался http://art.photo-element.ru/ts/caffenol/caffenol.html |
| Автор: | ian green [ 18 янв 2009, 17:13 ] |
откуда то из rec.photo.darkroom давно сохранено: ----cut on---- Caffenol Film Developer Formula Caffenol Caffenol film developer Water8 oz Arm & Hammer Washing Soda2 tsp (level) Folger's Coffee Crystals4 tsp (slightly rounded) Mixing instructions: Mix soda until completely dissolved and solution is clear. Add coffee, mix until all grittiness is gone and solution is uniform, let stand 5-10 minutes until microbubbles clear. Use within 30 minutes. Dilution: Use undiluted Starting point development time: 30 mins Notes: Gives imagewise stain and general (fog) stain. Caffenol C Caffenol C film developer Water8 oz Arm & Hammer Washing Soda2.5 tsp (level) Ascorbic Acid or Erythorbic Acid (97%)1 g* Folger's Coffee Crystals4 tsp (slightly rounded) Mixing instructions: Mix soda until completely dissolved and solution is clear. Add coffee, mix until all grittiness is gone and solution is uniform, let stand 5-10 minutes until microbubbles clear. Use within 30 minutes. *1 g = approx. 1/4 tsp Dilution: Use undiluted Starting point development time: 12 mins Notes: Expect slight film speed increase (1/3 to 2/3 stop) and little or no stain. Reduce agitation to eliminate flow marks. Caffenol LC Caffenol LC low contrast film developer Water8 oz Arm & Hammer Washing Soda2 tsp (level) Folger's Coffee Crystals2 tsp (slightly rounded) Mixing instructions: Mix soda until completely dissolved and solution is clear. Add coffee, mix until all grittiness is gone and solution is uniform, let stand 5-10 minutes until microbubbles clear. Use within 30 minutes. Dilution: Use undiluted Starting point development time: 30 mins Notes: Low contrast developer. Use with microfilms to give pictorial contrast. Mild imagewise stain, little or no general stain. This information was kindly provided by Donald Qualls. For more details please visit Donald's page of Dilutions and Times Caffenol LC+C Caffenol LC+C low contrast film developer Water8 oz Arm & Hammer Washing Soda4 tsp (level) Ascorbic Acid or Erythorbic Acid (97%)0.26 g Folger's Coffee Crystals2 tsp (slightly rounded) Mixing instructions: Mix soda until completely dissolved and solution is clear. Add coffee, mix until all grittiness is gone and solution is uniform, let stand 5-10 minutes until microbubbles clear. Mix 1/4 tsp ascorbic acid in one quart water, and use 8 ounces for the developer. Use within 30 minutes. Dilution: Use undiluted Starting point development time: 20 mins Notes: Speed-enhancing low contrast developer. Use with microfilms to give increased speed with pictorial contrast. No detectable stain. This information was kindly provided by Donald Qualls. For more details please visit Donald's page of Dilutions and Times ----cut off---- |
| Автор: | serzz [ 18 янв 2009, 17:40 ] |
Я как шутку пОстил! :shock: Кто-нибудь из присутствующих сам непосредственно пользовал? |
| Автор: | ian green [ 18 янв 2009, 18:20 ] |
когда нашёл эти рецепты попробовал один раз полутонов не получил вообще соду правда обычную пищевую использовал надо время явно больше чем указанные 20мин но 8часов это как то слишком на d-76.ru в форуме вроде бы это обсуждалось когда припрёт тогда будет смысл морочиться |
| Автор: | cfif23 [ 18 янв 2009, 18:24 ] |
ian green писал(а): когда припрёт тогда будет смысл морочиться
Вы думаете припрет? Я уж D-23 намешаю 2 ингредиента, качество выше |
| Автор: | serzz [ 18 янв 2009, 19:22 ] |
Где- нибудь .... на пленэре |
| Автор: | ian green [ 18 янв 2009, 19:26 ] |
а вот что с фиксированием солёной водой? реально и насколько стабилен результат? |
| Автор: | Razer [ 05 июл 2010, 14:06 ] |
Я проявлял в соде и лимонной кислоте, правда засветил пленку, =( обираюсь попробовать ради эксперимента и другие рецепты, отпишусь как сделаю, пока апну тему, чтобы не забыть=)) |
| Автор: | varjag [ 05 июл 2010, 14:19 ] |
пусть еще попробует фиксировать в моче |
| Автор: | ian green [ 05 июл 2010, 15:16 ] |
Urine as a developer http://photo.net/black-and-white-photo-film-processing-forum/00Wnnn |
| Автор: | MANontheMOON [ 05 июл 2010, 22:58 ] |
На Д-76 пошли даже дальше http://d-76.ru/main/forum/index.php?showtopic=432 |
| Автор: | Stjarna [ 06 июл 2010, 09:39 ] |
тему переименуй, автор |
| Автор: | vnukov_pk [ 06 июл 2010, 10:24 ] |
кроме шуток - на листе zenit camera group один из участников регулярно публикует примеры фотографий, сделанных в каффеноле. он предупреждает, что эта хрень нереально воняет. примеры тут: http://www.flickr.com/photos/joaofreita ... 092011983/ |
| Автор: | QUAsit [ 06 июл 2010, 10:37 ] |
vnukov_pk писал(а): эта хрень нереально воняет/
Запах творчества приятен всегда |
| Автор: | Nicolas [ 06 июл 2010, 14:42 ] |
Вообще-то тема не нова. В 19-м веке пытались (до применения желатины) заменить чем-нибудь мокрый коллодий. Нужно было что-то похожее на эмульсию для сухих пластинок. Так вот, была масса рецептов с чаем, кофе и даже пивом - лучше всего подходил портер. Причём это не первоапрельский розыгрыш - я давно хочу материалец подготовить. |
